We are having 40 - 50 MPH winds and my station is only registering 20 - 25 mph wind speeds. All stations around me are also reporting 40 -50 MPH winds and 60 MPG gusts. Brian can you check this please?
Ok, I just checked and I actually get a higher wind speed when I select th 2 poll setting rather than the one poll. I thought the 1 poll was supposed to give higher readings?
what version are you seeing this in?
What you report hasn’t been my experience. 1 pole setting gives higher values.
Had to not only check the 1 pole box but return to the setup and uncheck the 2 pole box.
Brian
Henderson, NC
Hum… I now have 2 boxes checked. These really need to be radio buttons to mutually exclude the other options.
I’m running WD version 10.16s
I just ran with 2 pole for a while and now 1 pole and I see no differences.
Another anoying thing that happens when you change from one pole to 2 pole and back is the a spike is recorded in the barometer graph.
I agree. There are a number of areas that have this issue.
Brian,
Could we address this by leaving them as Feature Suggestions?
Brian,
Did you get a chance to check on this?
you mean to have them as radio buttons?
yes, i should do that, its a good idea
