Information Pws dashboard using product ecowitt
As soon as the sensor detects the leak, it emits a sound of about 90db and immediately the red drop appears in the console indicating the detection of the leak. as soon as the quantity of water in the sensor decreases, the “red” drop in the display disappears immediately (after about 3 seconds). In the php array of the site test we see that the signal goes from 0 to 1. Would there be some way to implement it in the pws_dashboard? thanks
Immediately only because it is local in your house and the sensors are checked by GW1000 or console continually.
Normal weather-websites get the data less frequent, every so many minutes, often every 5 minutes, max once / minute.
I will try to add some code in the next release.
Ok thanks a lot Wim.
Hi Wim, I saw that a new site update has been released. Did you add the leak sensor ?? Thanks
This is a full replacement and it did not include new sensors.
I will look into that when there is time.
