Incorporating climatedataout.html into Carterlake/Saratoga Template
What’s the best way to include climatedataout.html into my template? Data won’t be updated daily if I simply cut the html and paste into the template.
I’ve tried copying the climatedataout.html and renaming it wxlocal6.html.
Then in Control Panel/Web files-Web pg/Custom Web page Setup, I entered wxlocal6.html under Local filename3 and entered wxclimate.php for Remote name3.
wxclimate.php has the copied code w/ tags from wxlocal6.html and is on the remote side. All I get in the wxclimate.php is my base site pg with the tags w/out data.
http://www.knology.net/~blackjack52/wxclimate.php
Has anyone created a custom file w/ tags and included them in a Carterlake/Saratoga template?
something like this??
http://www.snoqualmieweather.com/wxclimate.php
Amen!
lol… i can send you the script and testtags needs for it, and the template so it looks the way i have it. I can send it after work, but im sure someone else will beat me too it…lol
Adding something like this is on my list as well. I could do without the snow column though…
Checking it out I see that it is getting properly uploaded (at least the current month). Hopefully when I get this going I’ll have the history as well.
http://azjerry.com/weather/climatedataout.html
Here is the original thread for the climatedataout template. Some other people also made a few changes in the download and attached a file to download. so Not really sure which one in that thread is the most current. But worth a look.
http://discourse.weather-watch.com/t/35722
I didn’t find that one. Thanks, I’ll take a look.
Thank you. That set me up. Easy setup too.
Great script.
Looks good.
