ImageSalsa
How I configure “ImageSalsa” with WD? I try that same way as VWS but ImageSalsa not understand WD’s tags. (?)
Supported weatherstations page say only: “Now compatible with Image Salsa”
Br,
Eki
under setup, general and misc, tick, enable a vws out put file (data.csv)
and set image salsa to use that…
but i think there is some problem…at times…i dont know what, and neither i think does jason
Yes, I found it now. Thanks. But as you say, there is some problem.
Only tag what I can use is and Hmm… :frowning:
Eki
maybe you can work with jason to see what is wrong?
Hi, I am looking for this also. I am having trouble finding the location. I click on setup, and I assume control panel, but I can not find a general icon or find it under anything else. I am sure that if it was a snake it would have bitten me by now…
CT
setup
then
Extra setting/Misc setup…
you will find the option under there for image salsa file creation
I did not get this work ever.
But then I bought “serial splitter” Now WD+WDL+VWS+ImageSalsa work together fine.
You can see result here (click webcam) http://www.antto.net/saa/flashgb.html :wink:
Cheers
Eki
Hi Eki. You are right, it does not work. Do you have any ideas on why? I would really like to get it to work, but cant go to the expense that you did to get it working. Were you able to determine what was not working? It appears that the data.csv file is being updated, but is not being read by image salsa properly. Is it a formatting problem? I need a .csv file from vws to try and see if I can see if I can make that work. I need to download vws and try that.
Brian…Thanks and I found it exactly where you said. I have emailed Jason and am going to try and get this working. It should work right?
Thanks…
yes, comparing to a vws produced file is a good idea
hey, great to hear the serial splitting works
Hey Brian…
I loaded vws and compared its output for data.csv to that of weather display. I was able to get the data.csv from weather display to work. The problem seems to be the seventh number, which is supposed to be the number of seconds. Weather display is putting a 3 digit number in that field and it is throwing image salsa off. I took a data.csv produced by weather display, edited that field for seconds from a three digit number (796) to a two digit number that would indicate a second and it worked.
Here is the file from vws (Data.csv):
1,2004,10,31,19,20,26,0,0,112,44,69,79.7,71.2,30.04,0.36,0,0,0,0,0,0,0,0,0,0,0,0,71.2,80,74,60.5,0,-0.5,0,0,0,0,0
Here is the file from Weather Display (Data.csv):
1,2004,10,31,19,28,796,0,0,112,43,70,81,71.2,30.05,2.482,0,0,0,-148,-100,-148,-100,-148,-100,0,0,0,0,80.9,74.3,61,0,30.4,32,0.015,32,32,32
It is placing a 796 where the seconds should go. The other differences come from vws outputing a 0 for sensors I do not have and weather displaying using other numbers. That does not seem to be a problem, I do not think.
Is there anyway you could look at this and see what weather display is doing?
Thanks…
That is, it is placing a three digit number where seconds should go, it is not allways 796.
bingo
my fault
i was using milliseconds instead of seconds
uploading a fix now as a new 10.18v
it will be ready in about an hour or less :slight_smile:
10.18x will be the version to fix this at long last hopefully
ready soon :slight_smile:
Brian…that fixed it, it works now. The only other issue I see is the field for outdoor temp rate (34) and indoor temp rate (35). These seem to allways be shown as 32:
1.00,2004,10,31,23,59,0,0.0,0.0,112,41,82,80.4,68.7,30.067,2.482,0.000,0.000,0,-148.0,-100,-148.0,-100,-148.0,-100,0.000,0.0,0.0,0.0,80.3,69.0,63.0,0.000,32.0,32.0,0.004,32.0,32.0,32.0
However, no need to fix them on my account, I do not need to use them. Thanks for the assistance with this, I am glad to see it working!
Now, to figure out how to do something like this from lighthouse weather. This guy has a great site.
Brian…how about another question?
The field for weather condition (19) does not seem to change off of 0 (clear). Would it be possible to have this based on the whatever you are using to determine the weather condition, for example, the metar you are using? For example, weather display clearly thinks it is overcast here as it uses the local metar. But, instead of using a 4 in the weather condition field, it uses the 0.
Temp and everything else working great with version X.
CT
looks good.
but,
you do realise that you can accomplish quite a bit with weather displays custom screen?
(but not as flexible as image salsa)
see this persons custom screen, done with WD :
It looks good too. Yes I know that.
But can you change data2.csv file too. That include metric values. data.csv is US-unit.
I have WD ver. 18x and data2.csv seventh column is xxx
Cheers
Eki
ah, ok, yes, i need to fix that one too
it has the same bug with the millisecodns instead of seconds?:
its great to get this fixed
i am surprised no one, including jason, was not able to see what was wrong before now
If you could fix that it’s great!
Yes, that has been problem long time. Big thanks to “lknweather”!
Can you check windcill and gust values too?
Cheers
Eki
Here is columns what I can nominate (vws data2.csv)
Columns name
1 Station
2 year
3 month
4 day
5 hour
6 min.
7 sec.
8 wind speed
9 wind gust
10 wind dir
11 in humidity
12 out humidity
13 in temp
14 out temp
15 barometer
16 annual rain
17
18
19
20
21
22
23
24
25
26
27
28
29 windChill
30
31
32
33
34
35
36
37
38
39
