I am completely new in this forum and in the personal weather station world !
I have purchased a Cresta WXR815LM weather station, which is exactly the same as TE923 models. Everything works fine excepted when I connect my USB cable in order to transfer data to the PC. Minutes after minutes, I loose each of my external sensors and I need to reset the station to recover them.
Has anybody already faced (and hopefully solved) the same problem ?
Indeed, it looks like it is a matter of distance between central unit and probes.
Bringing them closer removes the problem. Perhaps I was at the limit of sensitivity and activating the USB connection made the link broke (interferences, lower electrical resources, … ?).
Thus for all those people who face the same problem, just try to reduce the distance between sensors and central unit and it should work.
