I just downloaded the free trial of this product
And I went through the setup proceedure and then started the program. And it upon start-up, the program just locks up- I have to turn the program off to unlock my computer. Any ideas what is going on? It is a windows 98 machine with zone alarm pro on it. It doesn’t appear that zone alarm pro is blocking it though.
Rick
Rick,
Can you provide information on the type of weather station you are using?
Dave
if you have the client/server setup, and you have it set as a client, getting data from a server, then zone alarm will block it until you OK it
try starting again fresh:
delete the file wdisplay.ini from c:\windows or c:\winnt
and
delete the registry entry
wdisplayftp.ini
from the registry, using regedit.exe
