Control Panel > Weather Station type and station settings > Weather station selection > Ultimeter 2000 / 2100 > ‘I have a humidity sensor’ can be unchecked, but even after ‘close’, and ‘save and exit’, ‘I have a humidity sensor’ is checked again.
ok, must be a bug
i will look into it
( i was re working some of that weather station setup, and that was one of the things I was working on (i.e that it should be ticked, unless you actualy have a ultimeter station (but you say its not be kept unticked? (i.e you dont have a rain gauge with your ultimeter 2000?))
ok, must be a bug
i will look into it
Correct, I have a Ultimeter 2000, but no humidysensor.
And when I untick ‘I have a humiditysensor’, that doesn’t be kept unticked, next time I open the station type settings.
I have a raingauge with the Ultimeter; a raingauge with possible problems.
i was able to dulicate and fix this
a new 10.16b beta will be OK
OK, I look forward for it.
Hopefully I can make use of my raingauge now.
Peet Bros says me to send the junctionbox, and/or the PCB from the raingauge for testing and/or repair.
It might take a long time before I get my stuff back…
Can you explain the checkbox ‘*10 rain amount needed’?
the *10 was needed by someones setup/rain gauge/ peet bros station type....the problem is peet bros keeps changing things,.....
hmmm... :? ... why am I not surprised? ;-)
Anyway, I can 'tell' WD that I have a Peet Bros Raingauge 'Pro' precise to 0.01" of rain, and that I use mm. of rain?
