I found out how to do it…vers 9.85c
it creates a back up file in a new databckup folder, daily (just before midnight) of the main data and logfiles data
you can also use the zip feature manualy (see under setup, backup your data)
this has been a request from a long time ago!
thanks for that one Brian …this is a very useful addition.
That’s great Brian. Thanks!
Any chance of adding an option to ftp the zip once a day?
note, its a date stamped zip file too (i.e the month number)
Hi Brain
The zip backup looks good!!
Thanks 8)
Cheers
MikeyM
I see the new option under setup, is there something I need to do to use it? I highlight it and the menu closes and goes back to the main screen. Is it automatically doing the backup every night… should there be a checkmark by it or something? I don’t see any options, so I am not sure I turned it on…
Thanks for your continued work Brian!
Thanks Brian!
Is it possible to change the repertory to backup it on another Hard Drive??
It is the way I make my backup… it is much safer than to do it on the main HD, because if it crash… you loose everithing…
Thanks for your answer…
its automatic at this stage…no setting up needed
i will add the options needed soon
9.85d is ready
you can use it manulay now, and you can change the directory, and tick to upload to the web site too
Thank you Brian. It’s almost embarassing to receive so much value for the small price of WD…
i have added a paypal donation to the main wd web site, of 7 $US, if anyone thinks they have received value for money over the years ( i have had this suggested to me many times before)
ah yes now I ve seen your paypal add
its to discreet there Brian
its almost down the page !
Should be placed more dominant
so you can spend some more time
to develop (don’t let mum reading this !)
but I think thats not your style
its is (supposed to be ) automatic though, just by running the new version…simple
(although it did not automaticly back up the foles for me last night,…did it work for anyone else?
its is (supposed to be ) automatic though, just by running the new version...simple (although it did not automaticly back up the foles for me last night,....did it work for anyone else?
Hello,
Not for me… no autaumatic back up… it doesn’t work… sorry
i will do some testing and see whats up (it should have worked in theory)
Brian,
9.85c didn’t do an auto backup last night here. Just installed 9.85d and we will see in an hour or so what happens. I just clicked the Setup,backup menu item and then clicked ‘backup now’. Got repeated errors “unable to find c\winntwdisplay.ini”. Looks like you are missing a "" there.
Fred
Brian,
Just past midnight here and no zip file produced. Only entry in the backup file is the result of my earlier test. Again this is with 9.85d.
Fred
vers 9.85e is OK, i tested
whew
installed e this morning, will have to wait overnight to check.
Fred
