If I enter an offset to the humidity, the dew point also changes to correspond with the new humidity level. If I use the slope adjustment on the humidity instead, the humidity changes but the dew point corresponds to the original humidity level. Is this the way it is supposed to work?
no
i am not sure why the humidity slope does not seem to gel correctly…as I apply it right at the first variable storage for humditiy from the weather station…
what weather station type?
Peet Ultimeter 2100.
ah, i have not hooked that slope adjust into the ultimeter raw humdity…i will do that for the next version
Thanks!
