Can someone go through and make a new document for the install.
I am also getting confused with what is commands and what is just comments in the original. Can this be changed as well.
I think the install is much easier than people think
you should just need to copy (as sudo) the files in the deploy folder to /usr/lib/ and /user/local/lib/
After a bit of trial and error and re-doing some steps, it looks like I have got something working, BUT, I am now getting a message (in command screen),
“looking for file /home/pi/outdata.txt”
and displaying this.
I have added a file to the folder but it is not excepting it or not recognising it.
I did these steps again: sudo ./configure && make at the end you will get an error 2 in the make part, ignore that
sudo make install
this finishes without errors
and did your suggestion after that. It got rid of another problem I was having with the “libhid” file.
So, I don’t think it is running as it seems to be held up with the missing file. Below is the final parts of the output in the Terminal screen: univeral update rate 2
utc hour=3
local hour=13 Weather Display vers WD_console_17.6
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks! www.weather-display.com
sudo make install
but those were not my suggestions
I just suggested to simply copy the library files from the deploy folder..would have been interesting to see if that worked
now, it is running
but it looks like a problem with the station type
what do you have that set as in the config.txt file (see my post above)
Have made some progress (trial and error).
Changed the station type to 34 (universal).
Set the Comport to 1.
Get this now:
Data OK
Current data 15:54:55: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:56: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:58: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:59: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 15:55:00
**** updating clientraw extra files
**** updating data logs
updating wunderground
Sending WU data now
updating records to ini file
WU data to send https://weatherstation.underground.com/…
Wunderground data send Ok 15:55:02
Data OK
Current data 15:55:04: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:55:06: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:55:07: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
…etc…
THEN THIS:
Current data 15:55:59: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 15:56:00
Data OK
Current data 15:56:02: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
…etc…
My …etc… means same type info following.
A couple of issues are that the Temperature is wrong, and the Wind information and Humidity are not correct (seems to be 0). Barometer is actually 1017.8, so that is wrong, but at least getting somewhere.
I have been running Meteohub software, but had problems with the Micro SD card and file failures.
I like the look of your product better and hence tried to install.
Are there certain Linux commands that you run in your programs to open the USB interface and extract the data?
btw, when I do a lsusb on the RPi, I get the following which indicates it recognises the WMR300.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0fde:ca08 Oregon Scientific
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
