From the godaddy hosting features table, looks like you can have 4 or 5 (but how that’s determined is a good question):
From GoDaddy:
[color=green][b]"Support Staff Response
Dear Linda McElwee,
Thank you for contacting online support.
At this time you can upgrade to php5 through your Hosting Control Center or through your php.ini file"[/b][/color]
Looking at the FAQ it appears you may be able to run things under php5 by changing the suffix to that, so you could try test.php renamed test.php5 and see what it returns. If that works then it would be a way to test your scripts under 5 without switching over.
I had realised that I need to change the code which works out the times on the graphs so that it displays correctly when running WD in both 12 and 24 hour modes. In order to test this could someone who runs WD in 12 hour (ie AM/PM) mode please let me know (either here or in a PM) the whereabouts (URL) of their clientraw files that I might use for testing?
PM sent
Thanks to both Jim and Linda for the PM’s, I can now test this…
That seems to work. There’s gonna be a whole lot of file renaming going on I betcha.
That a good way to test compatibility with php 5, but once you switch to 5 using your hosting control or php.ini file then .php scripts will run under 5, you won’t need to change the names.
OK…even better
On further investigation GoDaddy can handle both at the same time. If you want to use mixed extensions “php and php5” then all you hve to do is use php5 for those files and just plain php for php4 files.
I have just completed updating my graph page to reflect the 7 day graphs. I have been unable to get the temp_7days.php graph to work on my site…all others are fine.
http://www.i40exit319weather.com/wx11.html
Could someone provide me with some areas to check…at this point I can’t see the forest for the trees.
Ronnie
Ronnie,
If I just run the temp_7days.php graph on its own, by putting http://www.i40exit319weather.com/graphs/temp_7days.php into the address bar, i get the following error:
Warning: array_walk(): Unable to call NegVal() - function does not exist in /home/content/....../html/graphs/temp_7days.php on line 22
(I’ve removed part of the path for your security). So i expect there is an error around line 22 of the code, I had something similar but off the top of my head I can’t remember. I’ll haved a look & try to remember to get back.
Ian
Ronnie you have not installed the latest version of the graphsconf.php file. When updating the graphs you must install the latest graphsconf.php as well.
That was it! I had that problem also #-o so that’s your answer.
I see you have it working now
Thanks for the assistance everyone…working fine…
Ronnie
I have now got my latest set of graphs ready for public viewing. I have setup three sets to look at
First set using metric + MPH and my own data
Second set using US measurements and a US website’s data
Third set using US measurements and another US website’s data
These graphs have more user customisable information, you can choose the plot line colours as well as all the units. They will attempt to handle negative values correctly in all temperature related graphs and should set the y-axis scale accordingly. These graphs are currently running on PHP4 and JPGraph 1.20.5, they have also been tested OK on PHP v5 and JPGraph 2.3.
Please let me know what you think. If all looks OK then I’ll plan to get a package ready for downloading in a day or so.
Wow, I know how much work it is to put together a set like that. A couple of comments based on the first graph of the first US set. Mixed resolution of the displayed values causes confusion. The vertical scale, 0, 0.01, 0.01, 0.02, 0.02 appears confusing because the legend resolution doesn’t match the scale increments, and then the single dp value on top of the column is 0.0, apparently not matching the graph.
Niko I missed that. The problem is with rain in inches and the number of ticks on the y-axis. Apparent;y its possible to get values like 0.252in of rain, now I mistakenly assumed that since most if not all rain guages had a resolution of 0.01in like my Davis I would always see values of multiples of 0.01in - not true. The issue with the y-axis labels can be sorted by having only very other one, but usually when there is more than a small amount of rain you need each tick labelled. This needs some more thinking about and maybe some more php code in the graphs themselves. The amount labels on the column tops were missing because I’d left out a line in some of the graphs - oops.
I think you see those extra dp’s because the inch data is stored in mm by WD and that introduces some small errors when converted back to inches for display.
Yes you are correct, I’d just looked at the code. I round the result to 2 decimal places at least that’s what is coded but its not working as I expected… Need to get some ZZZZZZ’s now I’ll look again in the morning.
Right guys time to try again. Fixed the problems noted by Niko and another couple I noticed myself.
Let me know what you think…
