How to report an Internet bug/problem
When you find that is an issue with weather display and an internet function, many things can be at fault. Before you post a bug report take a look at some information.
* Check the program error log in Weather Display - File called “programerrorlog.txt” in the main Weather Display program folder.
* Check the ftp error log in Weather Display - File called “ftplog.txt” in the main Weather Display program folder.
* Have you changed anything, such as ISP, computer, etc
* Can you connect to the server using another 3rd party ftp program
When posting a bug report, be sure to include
*connection type (cable, dsl, dial-up)
*computer specs (Operating System, memory, CPU)
*any other programs running (Seti, web cam software, p2p)
*station type
*webpage address
*version & build # of Weather Display
And if all possible, name your bug report something descriptive. Help!!! FTP broken doesn’t help someone looking through old posting, looking for a possible solution to a problem.
:smiley:
ps this may be better as sticky in the bug reports topic ?
