Hi guys,
I have just moved WD back to my old laptop as I have moved a lot of my 1-wire network off the weather PC. The problem I have is that I cannot get WD to remove the extra temperature ROM ID’s. I can delete them, hit the save/reset button in the 1-wire setup, but when I restart WD, the ROM ID"s are still there. I have deleted the wdisplay.ini file, but this has not helped.
Any ideas on how to permananetly delete these ROM ID’s? At present my main station temp reads -20C as the sensor it is looking for is not there.
EDIT: Loks like a lot of settings are really messed up with WD, is there a way to default the program back to a clean start position?
