how to put leaf wetness, soiltemperature, hyperlink in wdl
Julian,
WDL is great, but how can I put the soil temperature, the leafwettness or other wd parameters in the window? in your pdf file you are writing about a hyperlink, but can give an example. Do I have to change the the config file or is the hyperlink working with the normal html webfiles?
For a turfgrass diseases I can send a email warning. is it possible to get this warning in wdl?
many questions as you can see.
http://home.tiscali.nl/doornenburgweer
regards,
gerard
You can put any of the extra sensors into WDL by adjusting the config file.
Have a look at weatherbee's site at http://www.shermanctweather.com/index1.html. When you mouse over the instruments you get links to more information. Clicking on them will open a new window. Again you can set these links in the config file.
No, sorry.
Julian
Julian,
thanks,
this was fast and clear.
will work on it.
gerard
