I’m having problems with the icons. I think they started a couple of weeks ago when I moved my main WD to another PC.
a) The moon pic is showing the wrong phase, it’s wrong on summary.gif and sunmoonimage too.
b) The current condition is only either the starry night all day and night, or rain, on summary.gif and the screen shot.
My PC time and zone are correct. My lat/long is correct. My sun and moon rise/set and % are calculating correctly.
What am I doing wrong?
P.S. Can I assume it’s OK to use the WD logo as a clickable link on the webpage? My host switched from random banners to banners of google context sensitive ads and I found myself advertising Weather View 32 yesterday 8O so I thought I would add “Powered by WeatherDisplay” so it shows up right under their banner.
which version of WD are you using
the moon issue has been addressed in the beta version and i am keeping an eye on it but it does update if you restart it yours looks like mine did before beta version
in summary image brian put an extra tick box in called produce and upload metar images for each metar listed, i found if this was ticked the icons behaved themselfs at least they did for me
Q: which version of WD are you using the moon issue has been addressed in the beta version and i am keeping an eye on it but it does update if you restart it yours looks like mine did before beta version
A: This is 997d, I have beta running on my other station, and that’s how I realized the moon was off. One issue resolved!
Q: in summary image brian put an extra tick box in called produce and upload metar images for each metar listed, i found if this was ticked the icons behaved themselfs at least they did for me
A: I’m not using any metars, so I’m not sure how/if this would be the problem for me, but I’ll play with it.
It all works on the beta www.kirkwoodmanor.com/wxm/montwx.htm but not on my other station - the www listed below. I’m pretty sure the conditions icon used to be OK, but went off the rails when I moved WD.
suggest that when you are happy with the beta version you update the other machine with it or try 9.97h, if i remember right there was a problem with icons on this forum before not sure when
email me your settings nikosheapeard, and i will have a look
(wdisplay.ini from c:\windows or c:\winnt)
and wdisplayftp.reg, from databck up folder, affter going, action, back up registry
a new 9.99e beta is ready, hcorrin, it should this time fix the yesterdaygrpah issue, and nikoshepared, it should be better for the double log entry for the vp (stop wd fopr 10 minutes say), and the vp receptionn inof format might be better
