How to display Solar Sensor in WD Graph
Running WD 10.37S-B150 on Windows 11 with a Davis VP2.
I added a Davis solar sensor to my weather station today and have set it up in WD and I am looking for suggestions to get the solar data to display in the WD temp/RH graph.
The data is in WD as shown in the Solar Setup → Current Readings tab:
The main WD display is also showing the solar data at the top left of the window in the Current Conditions section but it’s not being plotted on the graph:
Here are my chosen options in the Solar Setup → Graph Plot/Misc Settings tab:
The other pertinent tabs in the Solar Setup are:
Can someone point me in the right direction to get the solar data to display on the temp/RH graph?
Maybe Control Panel > Graph Setup > Solar/UV/Misc. Setup > Plot Solar?
Well, duh! I’m a moron. Thanks for the info.
