How to disable the Wunderground File Import popup?
Could someone please tell me how to disable the
Wunderground File Import popup? I cant seem to find
where to turn this off. See attachment.
It does not let my software connect to the console for readings!
Thank you!
James
Absolutely no idea. . . what happens if you remove the ID and click on OK? Or select Day File and see if the top Windows bar lets you turn it off? Or maybe you just have to restart WD?
If none of these work you’ll have to e-mail Brian.
Yes I’ve tried, it pops up, seems to lock up the software, then closes. Doesn’t give you anytime to edit anything, it just continuously opens and closes, and won’t let the software completely connect. Thank you though!!
