HOW TO ADD SNOWFALL
I am using Saratoga template. Here is my site: www.jeanrobertmarion.com
What i would like to know is how can i modify my dashboard to add snow fall for example ?
Thanks for helping me…i am a newbee ! #-o
Check out my alternative dashboard www.websterweatherlive.com (The spot that currently has LIGHTNING can be set to display snow instead, it also can replace ET with snow automatically during snow season) if thats something like you want, the script is available in the script section from the menu on the left.
Scott
Even with the regular dashboard, the snow display will replace the rain display when the temperature is below 4C (configurable).
See it on your current homepage by using the test of http://www.jeanrobertmarion.com/?snow=1
The error ‘Notice: Undefined offset: 1 in /homepages/29/d296596631/htdocs/ajax-dashboard.php on line 919’ appears in the demo because the snow today in CM is ‘’ (null). When you fill in a value in WD for that (like 0 ) then you won’t see the error.
Ken
I did exactly what you said and it work fine !
Great help thank you.
Jean-Robert
