How would I add a link to the bottom of the block to show a movie but keeping the block functioning the same
I would like to show https://weatheryyc.com/wx_data/videolastday.mp4 show in an popup
Step 1: Modify the _my_settings/webfilm_popup.php script.
1.1 Set the correct link in line 29 so it reads (in your case)
<iframe src="https://weatheryyc.com/wx_data/videolastday.mp4" style="margin: 0 auto; width: 100%; height: 100%; " frameborder="0" allowfullscreen>
1.2 Set line 24 to comment by adding a comment mark # at the first position
# die ('Script needs to be adapted to your movie first ') ;
1.3 Test: https://weatheryyc.com/pwsWD/_my_settings/webfilm_popup.php
=> Should show the movie
=> If it shows “Script needs to be adapted to your movie first”
==>point 1.2 is not done.
Step 2: modify the PWS_blocks.php to add the clickable link
2.1 Remove the comment mark # on the first position of line 423 and adapt the link to the correct script.
It now reads
#$blck_ppp [$script][] = array ('show' => true, 'popup' => '_my_settings/cam_movie_popup.php', 'chartinfo' => 'popup', 'text' => $movie_txt );
it should read (in your case)
$blck_ppp [$script][] = array ('show' => true, 'popup' => '_my_settings/webfilm_popup.php', 'chartinfo' => 'popup', 'text' => $movie_txt );
This is tricky, so better make a copy of the current script before making any change.
2.2 Test: https://weatheryyc.com/pwsWD/ should show the new link as in attached screenshot.
Succes, Wim
Working now. I just missed step 1.2
