I don’t seem to be able to correct the rain fall amounts in my data base.
you need to also go to :
setup,control panel, barometer offset and rainfall
then enter in the amound needed for day/month or year (or use the increase all by this amount)
then click on set (for each) then click on yes to save settings
OK, that seemed to work. There are just way too many settings. I wish all the settings for one category were in one control panel. Like have a rain control panel and anything dealing with rain is in that control panel. What is the action / view and correct the log file / rain totals? I’ve tried to use it twice, the only thing it seems to do is take up space in the actioon menu.
zip and email me your log file, 112004lg.txt
and i will experiment with the correct log file
(which enables you to correct the rain totals fors each day that are derived from the logfile)
Hi Brian
I am also having problems trying to reset daily rain on the (Temperature and Wind Trend) page. I can not find where to change this amount for daily rain amount. Thanks Joe
some of that data comes from the datafiles (the graph files)
so if you get the data correct in the log file, i.e 112004lg.txt (i.e aespecialy the rain totals around the daily reset times)
and then go action, convert wd log files to graphs, then that should fix it
Thanks Brian it works good, but it is a big job. Joe
