How do I correct data in "Trends"
If I go to view/trends, I get data in Weather Trends.
Two Questions.
  1. How do I correct the field where it says “consecutive days with no rain”? Mine says 16 days when in fact it is really 10. How and where do I correct this.
  2. The fields for “Last Year” are blank. It is now 1 year this month since I have been using Weather Display. So when does the information come from, and also, when is the “year” actually start? Is it from now - since when I started using this software, or from the beginning of the year, which would then be January 2004?
i will add a feature to correct the days since last rained
last year:
do you have a file called month102002.inf in the datafiles folder?
Nope,
The only ones I have got are month42003.inf onwards for some reason! If I did, I can’t recall deleting them as WD as been relatively stable since the beginning of the year.
Could it be because I hadn’t set up a log somewhere until April this year? Maybe you could clarify.
in the logfiles folder, do you have a 102002lg.txt file
No, sorry, I haven’t got that either. For some reason or my records appear to start from April 2003. Not sure why as you know I have been using WD since last year, and apart from some problems earlier this year, it has been running ok.
