How can I add the current solar reading to the dailylogcsv.csv file? Is this even possible?
if you had the source code for WD and a delphi compiler you could 8O
(but otherwise you can create your very own custom log (turn that on under setup,logfiles setup (using the custom tags))
Ok send me the source code and I’ll get started right away
How do I create my own custom log file?
When I create this custom log file will it be added to the dailylog.csv file? Sorry for so many questions but this is new ground for me.
