Brian,
what do you have set as the polling dealy for the wind direction/temperature
try setting it as 30 (then click on save reset)
also, have you seen, in the latest version of wd, i have tidied up the dallas 1 wire setup
also, which version of wd are you using (you dont actualy say)
Brian,
Where is this polling delay set?
Yes I did see the house cleaning and I like it.
its the very bottom setting on the extra/misc tab
set it as 30, then click on save/reset on the main setup page
For what it is worth, making the change from 0 to 30ms dropped CPU usage a factor of three here.
It was typically 10-30% and dropped to under 5 % according to WINDOWS system monitor.
Unfortunately, this isn’t a clean comparison since old numbers were with an older version.
Screen rewrites are still typically near 100%.
Brian
Henderson, NC
