Help
Hi I hope someone can help … I have uploaded the correct files and changed the index file as per instruction and it still wont work
the URL is www.lindstrand-x.info/Weather …
All that seems to happen is the the flash is loading but then stops … any ideas ??
Mike :?
Yes, it’s because your weather directory has a capital W http://www.lindstrand-x.info/Weather. If you change it to lowercase all should be well. I will fix that one day! :slight_smile:
Julian
Hi Julian,
Thanks for the prompt reply … is that the case even if the sub Dir IE with a W instead or a w ??
Mike
Yes - the whole path to the wdlconfig file.
Julian
Hi Julian,
I have changed it but still no joy … am I missing something
Weather Display Live
The address http://www.lindstrand-x.info/weather/ is giving me a 404 file not found error at the moment. Have you changed the W on the actual website directory?
Julian
Hi Julian,
No not yet I guess I need to do that …
Mike
Hi there
It’s working fine except for one thing - it’s a little out of date which I would think means that your WD program is not updating the clientraw.txt
Is this the case?
Cheers
Hi Graham,
Thanks for the prompt reply you might well be right any idea where I should look ?
Mike
Have a look at the first item on the FAQs Weather Display FAQs
Julian
