Help with pws dashboard site
Hi pricey,
I am confused. Two days ago you were using easyweathersetup as posted in this topic
Your problem now seems you moved the unzipped folder (normally named pwsWD) to the wrong place.
Your website scripts and folders should be inside the “public-html” folder.
That “public-html” name can be different as providers can use other names also: “html” or “wwwroot”
When the unzipped folder is in the correct place, all should be accessibles again, as it was 2 days ago.
