Robert,
It sounds like what you are proposing is exactly what I’m planning on doing within the limitations of the VP2 and my house configuration.
Regarding the rain gauge… Davis tech support says that your rain gauge solution won’t work. I.e., with the VP2, you cannot simply disconnect the VP2’s rain gauge from the ISS and move it. Apparently the rain gauge is physically built in to the ISS. (However, the VP1’s rain gauge could be moved.) If you move the rain gauge, you also move the solar panel, solar radiation sensor, and temp/humidity sensor.
So, the only way to “move” the VP2’s rain gauge is to buy another one. Personally, I think is this is a stupid design, but tech support assured me that it’s built that way on purpose.
Regarding the anemometer… You’re right - extending the cable is trivial. What you are suggesting about simply extending the anemometer cable was my first idea. However, that’s the easy part…
The hard part is running the cable. My house has 36" eves all the way around the house, most of which are between 15 and 25 feet off the ground. It also has a cedar shake roof, which is slipperier than wet cat ca-ca when it rains (which is a lot in Seattle). The combo of these make it VERY difficult to run wires. So a wireless anemometer makes the install MUCH easier and safer.
Below is a drawing to show what I’m dealing with. The drawing is NOT to scale with the front of the house being much higher off the ground. Also, I didn’t draw the front entrance deck just to the right of the MBR Deck (where the ISS would be mounted). There’s a big notch in the entrance deck from which grows an 18 foot bush. The only way to get to the corner where run the anemometer cable would be to put an 18 foot ladder right on top of the plant.
Note that the two anemometer masts are just design ideas to figure out which is the best choice. The one attached to the back side of the vent box is better and easier to install AFTER climbing up the slippery shake roof. The other is much more difficult to install and requires a 12 foot mast, but is much safer to install.
The second drawing is the same model from the back side. It doesn’t look far from the edge of the roof to the top until you step on the shakes. And watch your foot slide.
One of the reasons that I draw models is to parse through complex issues. Most problems look easy when you start. Some have easy fixes if you find the right solution. The ISS location is one of those. Some, like the anemometer, get much more complex when you work through the detailed design steps of actually implementing the solution.
Dan.
