Help Please
I’ve just installed Live, it all seems to be working fine from my local network, but when I tried to connect remotly through a corporate VPN & proxy server the site was giving the evaluation version warning.
Could some kind person go to the url below and let me know what they get
Keith
http://www.bacwak.net/html/current_weather.html
Looks fine from here (Blackpool). Is that you walking around in front ot the webcam (0918/0923 on Saturday morning)?
Works for me too. It sounds like the config file is stuck in the corporate proxy cache so it’s not getting your serial number. The software will only ever show ‘evaluation’ if it says evaluation in the serial number line of the config file. You can double check this by typing the url of the config file directly into your browser, which if it’s a reasonably modern one, will show the xml file configuration.
There are some hints and tips in the readme file for solving the caching problem.
Julian
Thanks for the reply’s. Looks like everything is ok then
And yes it was probably me, getting ready to start work in the garden
