WD ftp uploads are done via a separate program and so WD should not be pausing like that
what speed cpu, how much memory?
The clock in WD will pause while processing files such as logs, data and webpages/images for upload, then will commence again.
I get a 2 second pause every minute, and an 8 second pause every 10 minutes when all my webfiles are being updated, my PC is old but quite fast. I have seen WD running on a slow PC and the pause was more than 20 seconds when updating webfiles.
It is normal behaviour in WD.
You can’t do that with simple html. You can use one of the third party weather templates which use AJAX programming to update the data on the page without reloading the whole page.
here is my ajax web page, updated auto via the clientraw file
http://www.weather-display.com/windy/wx2.html
Remind me what weather station you have.
I built my site with no coding experience at all.
I’m using the Saratoga Script, which is very user friendly.
Rick
Great job Rick! I’m in the same situation - no experience with coding, etc. I have a GoDaddy acct and Linuix / domain. Did you simply build following the setup wizard or how did you start?? I’m at square 1!! Pointers??
It’s been so long since I put my site up (2015) that my memory fails me.
I remember a lot of trial & error. You’ll need an editor. Personally I use Notepad.
As I said before, the Saratoga script walked me through the process quite nicely.
Rick
