Thank you Ken.
I’ll give it a try. Your support is most appreciated! I couldn’t run my site without your and others’ technical support.
Jeff
Thank you Ken.
Jeff
Ken,
When I installed your new edited script the error log increased from ~ 1,000,000 in size to ~ 19,000,000 in size. Should I re-install the original “clientraw-parser.php” script?
What are the latest errors from error_log?
P Warning: Undefined array key 813 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842539 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842556 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 813 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 88, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842582 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 813 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 88, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842602 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 73, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842619 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 73, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842635 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 75, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842651 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 75, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842668 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 75, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842684 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 75, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842700 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 77, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842717 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 77, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842733 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 79, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842749 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 79, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842765 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 79, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842788 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 79, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842805 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 81, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842821 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 81, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842838 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 81, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842854 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 81, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842871 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 83, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842887 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantra, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.842960 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: ilweather.com/clientraw-parser/clientraw-parser.php on line 83, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843019 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 83, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843039 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 83, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843057 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843073 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843091 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843116 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 85, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843134 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 88, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843150 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 814 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 88, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843167 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 815 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 73, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843205 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Deprecated: preg_match(): Passing null to parameter #2 ($subject) of type string is deprecated in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 73, referer: https://indiantrailweather.com/
[Thu Mar 07 08:18:20.843224 2024] [fcgid:warn] [pid 398165:tid 4115149858560] [client 87.254.84.23:53687] mod_fcgid: stderr: PHP Warning: Undefined array key 815 in /home/baldwinj1/indiantrailweather.com/clientraw-parser/clientraw-parser.php on line 75, referer: https://indiantrailweather.com/
May be try the version on this page on Ken’s site under relayweather Saratoga-Weather.org - Legacy Scripts
Works ok on my site with 8.2
I get service unavailable for your site probably due to all those errors
Thank you Harold. I’ll give it a try.
Much appreciated!
Take care.
Jeff
