Help about overview and importing/collecting data
As a totally new user to WD there are already some question right in the beginning of my acquaintance. (I have a relatively long experience of collecting weather data using Vaisala professional meteorological equipment and other sensors plus > 15 years of software/hardware configuration)
  1. Haven
[quote]Step Two: Can I configure (customize) WD to accept online data as it is presented today? It does not follow any
Thanx NorCal Dan for a promt reply
There is a Vaisala MAWS201M listed
No. I’ve made the ouput file according to an old Vaisala instrumantation specification and using grafics from the early 90’s. So data output is not mentioned in WD.
Nifty
… Vaisala MAWS201M … Is that the equipment you’re using?
Here under is what I’m using :
VAISALA QLI50 SENSOR COLLECTOR: For use in extreme conditions (-50
How does the data come out? Does it have a serial interface, or can whatever software you are using with it produce a single line file of space delimited data that overwrites with the new data? If you can get the single line data file then the universal interface option could work for you.
yes, I am thinking this should be possible, to get the data into weather display
can you post here an example of the weather data file?
thanks
