I have been happily running on 10.37Qbuild46 for some time now and the 1 wire reader has worked fine, reading all my 1 wire temp sensors, solar sensor etc.
Yesterday I changed to build 52 and now the 1 wire reader consistently will not pickup all of the hubs - (Hobby Board Master Hub) - picking up hubs A,B but not C. When I initially start up it does, then loses hub C within a few seconds. When I change to other 1 wire readers I have they read these hubs fine no matter how long i run these programs, so I know there is nothing wrong with my hub or sensors.
Brian has there been a change to the 1 wire reader between build 46 and 52? Unfortunately I cant go back to build 46 as I deleted it before I noticed the problem outlined above (do you have old versions archived Brian).
Was just about to report a similar issue but decided to do a search first to see if anyone else has see this.
WD 37Q52, Dallas1wirereader.exe V4.1, file date 6/19/11
I have a Hobby Boards 6 channel hub. On channel 3 (Main) I have a leaf sensor from HB. If has been working flawlessly for over 18 months. I just installed WD 37Q52 and noticed that channel 3 (Main) was not reporting properly.
It reports .0047812500 on program start and all three channel lights scan, but after two readings the system rescans the hub (all 3 channels (M and A)) then after that it does not scan (no light) channel 3.
WD 37Q47, Dallas1wirereader.exe V4.1, file date 6/19/11
Same issue
WD 37Q44, Dallas1wirereader.exe 3.51, file date 5/23/11
No problem. Scans correctly after start up and reads .00578750, of course this varies depending of the sensor wetness.
I tried several version prior and all worked great.
So something happened between Dallas1w…exe version 3.5 and 4.1
Dave
Running windows XP Pro 2 gb memory, Pent 4, 32bit
Have ticked the debug window. What do you want me to tell you - about the stuff scrolling down the LH window or whats in the centre window - not sure which one you mean is the debug window.
Since my previous message, after numerous restarts I finally have it reading all my sensors. The number of times I had to restart WD to get this to happen suggests to me that everthing is still not kosha yet. Seems there could still be a timing issue with the hub polling?!?!?!?
Sorry the W was a typo should have been Q. My first post (2nd post above of this series) is correct and discribs the problem.
I have go back to 37Q44 as it has Dallas1wirereader.exe 3.51, file date 5/23/11 which works.
Dallas1wirereader.exe versions after this cause the problem, IE skips looking at port 3 (Main/Aux).
As a workaround, I am unable to use recent versions of 37Q like 37Q54 and then copy an older version of Dallas1wirereader.exe in the c:\wdisplay directory. The 1wire program will start but stops quickly. I assume it is not registred correctly.
P.S. I will be away until next Monday so will not be able to reply until then.
I think the problem will be where I had it re checking for sensors after start up
but I have stopped that re scan from occuring if a hub in use
did you try the latest version? (vers 4.2)
Sorry for the delay, have been on vacation.
Have been using 32Q57(c) [third upload-July 19th] for about 7 hours and all is working great.
Looks like that did the trick.
