Guys
A few days ago there was a thread posted where a user was very upset at WD and certain users even volunteered to refund this users cost of WD. Do any of you guys have the link to his web page. I was wanting to see how he does the java weather ticker across the top of his web page. TIA
I also have a java-ticker on my page… already over a year active !
(comes from : http://www.bluehill.com/freecgi/TickerTape/)
see the link below…
cheers, Aad
i am still working with rookie behind the scenes and we are making good progress
his web page is
I was asking for this too before the thread (wisely) disappeared. I found a slightly different one here;http://www.physiology.wisc.edu/ravi/test/applets/app8/ticker.html
and a big thanks to nikosphepared for his behind the scens help with imroving the davis VP extract data from data logger double log time entry and start up problem!
Ultima - Thanks for the pointer.
The url you sent me only has the java files and I do not have a java compiler on my machine.
Tonight I will create a zip-file with all the needed class-files in there…
Thanks a bunch.
You can download the following file :
http://members.rott.chello.nl/a.vanboven1/ticker.zip
Extract the .class files to your webfiles-directory en us the following code on your page :
[code:1]
[/code:1]In the last parameter you can put the WD-custom-tags.
Good luck, Aad
