Graphs problem -dont show
I installed succesfully the pws_dashboard with API Wunderground installation .All the site is ok. But the graphs doesnt display anything. why?
the site is Ψαχνά, ΕΥΒΟΙΑ, GREECE Home Weather Station (wu version)
The graphs files are build by the cron-job
Either with the historical data downloaded from WU or with the current data.
Please check
Succes, Wim
How can i find the chartswudata/IPSACH6YMD.txt from weatherunderground? i must write some code?
Did you select to use WUnderground for graphs on Data tab in easyweathersetup? If so, data should be loaded automatically, especially if you run the stationcron.
Yes I make this selection. What is stationcron? I installed the weewx to the raspberry and i send data to wunderground. I dont have additional server or i dont have installed additional program.
Must i buy the program WeatherDisplay ??Or some external server?
11_cron.pages (pwsdashboard.com)
