even @ default htm the graphs of my wether report are chopped off as in gif as in jpeg
it doesnt matter even when I call the specific wheater diagram it’s chopped off
anyone?
I tested with 2 different setups on different PCs …
When my WD has NO connection to the oredon WMR928 with one PC and a manual
opload it’s ok …?
strange!
especially the dials & the graphs 24h etc
even when I put then in different orders or direct uploads, strange …
Only when manually fored & the weather station isn’t coupled to the PC
it generates perfect graphs. I’m an IT my self and still wondering to find the cause …
Altough, I’m afraid it has to do something with my settings
Since no one else seems to have reported this problem
I’ve had the problem with version 10.12t (win95)
an 10.18c (win98SE); d and now I’m running 10.18f on windows 2000
manual uploads were done from win xp sp2 + 10.18d
I’m puzzled …
ah, you mean the dials image?
it will be some comination of the screen size on your desktop, your desktop settings, like font size, DP inch setting, and having wd set to use full screen size or not.
what does the image look like in the web files folder?
I’m also thinking in that direction, but in the web folders it’s luckly the same problem
but this doesn’t declare the problem with the 24h graph etc were the lower part i chopped off
the is nearly notext involved …
I’m partly a bit furious on myself since the cause of all this graph trouble is indeed a bug:
I forgot to set off my old laptop, which was still broadcasting ftp 1 minute after the other laptop (&win2000) + 10.18f
This old laptop is an HP Contura 430CX with active tft matrix 640480 standard VGA 16bit high colour (&win98SE) +10.18d
BUT I guess now that the graphs and dials and other stuff are best seen on 800600 SVGA and
that the pictures are made by gif or Jpg saving screenshots, since the screen of the old laptop is only 640*480 …
the graphs must be chopped of
I tested everithing toroughly, and I stay by this conclusion.
hi, yes, if the screen size is less than 800x600, then the window grab routine will miss anything less than 800x600
thats a limiation of the getformimage routine i am using
