Graph Setup/Reset Graph does not reset Indoor Temp (maybe also Indoor Humidity-can’t tell).
After doing the above all data lines on the main graph are flat except the Indoor Temp line.
This happens in XP and Win98.
On mine, the indoor temp is graphing off the chart on the webpage but is fine on the screen shot of the same graph. Did I miss something?
oh, i need to add a hook here to reset the indoor temp/hum too
jim, are you using the latest version?
