Graph setting - wind limit not working
In graph settings, I can’t get the graph limit for wind max to have any effect. It seems to do auto all the time. Anything I’m missing?
i never did implement that with the change to the new graphing format…
I need to do that
(and I also need to auto plot heat index if windchill not applicable!)
Oh. I hope it isn’t too hard to get that working.
Perhaps more in the wish domain … I sure did like how the graph used to have exact GAPS when WD was not running, instead of just collapsing the hour plot to a shorter segment. May not be possible with new format.
(I also thought the old graphs had higher resolution (single point peaks instead of double point peaks).
you can use the pad out data option at start up, to fill in the gaps with the missing data (straight lines)
point: i dont plot double point deliberatly, its just the way the component works…i cant help that
Hmmm, how do I do that? My start-up just brings up main screen.
its under setup,extra/misc settings
