Graph problem in Precipitation, wind and Barometer
When I call up the graphs under Precipitation, only today’s graph appears. The one of 30 days and the others don’t work.
The same also happens with Wind and Barometer.
I use the cron job that is integrated into WD.
https://www.weerstation-assen.nl/pwsWD09/index.php
What’s going wrong?
Brgds,
Oebel
Hi Oebel,
Please delete the ./wudata/IASSEN60-metric-2024.arr* which is stalled.
Probably the file will be correctly rebuild.
I will check later today if this solved this issue
You can also delete al the test-files ./wudata/IVLAAMSG47-metric-20??.arr
Those files only clutter your ./jsondata/ folder
Hi Wim,
Thanks for your help!
I just deleted the files. (2:28 p.m)
Now waiting for the result.
Edit: 3.45 p.m.: Problem is solved.
Thanks Wim!!
Brgds,
Oebel
