Graph prblems with restarts
This is an old one but it would ne nice to have it fixed:
When WD is shutdown and then restarted, both the Solar/uv/ET and real time graphs will have numerous spikes all over them. It would be nice if this could be fixed as I always have to clear those two graphs when restarting to eliminate the problem. I’m using a Davis VP Plus.
is this happening after a data extraction from the data logger?
It’s difficult to say as I can’t easily dtermine exactly where in the cycle it is occuring. I do know that it happens every time that I start WD. The problem seems to be worst on the E.T. graph on the Solar/UV sensor graph.
Tom
hi is this happening after a data extraction from the data logger?
i would guess that its the data from the extract, and i dont have the number correct (i.e out by a factor of say 10 or something)…and then the real time graph overscales…(i.e lines from top to bottom and it gives a way over the top reading when you move the mouse over it…
is it fjust the et number that is not correct then?
i can add some debug code
grab a new version now ( a new 9.85d)
and then after a data extract, go to view, program error log, and look for the raw uv and raw solar readings, and let me know those valyes, and what they should be,.,…(i have made some changes/fixes too, hopefully as well)
Throughout the night there is a repeating indication of a UV of 1.0 or 2.0 for one reading when it is, of course, 0. The ET is even odder. It is zero until close to the end of the log and then it starts rising in a linear fashion until it peaks at 14.4 - this when it is just barely daylight out. The time period of this (when the computer was off) is from about 10:30pm until 7:15am. The logger is set to one minute intervals.
Tom
raw et= 0.0 raw uv =0.0
raw et= 0.0 raw uv =1.0
raw et= 0.0 raw uv =2.0
raw et= 0.7 raw uv =0.0
raw et= 1.1 raw uv =0.0
raw et= 1.4 raw uv =0.0
raw et= 2.6 raw uv =0.0
raw et= 3.3 raw uv =0.0
raw et= 4.2 raw uv =0.0
raw et= 4.4 raw uv =0.0
raw et= 6.2 raw uv =0.0
raw et= 6.3 raw uv =0.0
raw et= 7.4 raw uv =0.0
raw et= 7.7 raw uv =0.0
raw et= 8.1 raw uv =0.0
raw et= 8.6 raw uv =0.0
raw et= 9.0 raw uv =0.0
raw et= 9.5 raw uv =0.0
raw et= 9.7 raw uv =1.0
raw et= 9.9 raw uv =0.0
raw et= 10.0 raw uv =0.0
raw et= 10.7 raw uv =0.0
raw et= 10.9 raw uv =0.0
raw et= 11.1 raw uv =0.0
raw et= 11.3 raw uv =0.0
raw et= 11.4 raw uv =0.0
raw et= 11.8 raw uv =0.0
raw et= 12.3 raw uv =0.0
raw et= 12.7 raw uv =0.0
raw et= 13.0 raw uv =0.0
raw et= 13.4 raw uv =0.0
raw et= 13.7 raw uv =0.0
raw et= 14.1 raw uv =0.0
raw et= 14.3 raw uv =0.0
raw et= 14.4 raw uv =0.0
grab a new version now ( a new 9.85d) and then after a data extract, go to view, program error log, and look for the raw uv and raw solar readings, and let me know those valyes, and what they should be,.,...(i have made some changes/fixes too, hopefully as well)
humm, we need to deterine what units the ET is in (inches>?)
can you compare with data on the console or what weather link says?
thanks
It appears to be in inches and is completely off the top of the WD graph by many hundreds of percent. The VP console shows only normal readings, no data that matches what WD is reporting. Also interesting is the UV spike every hour or so and one other item I forgot to mention: I’ll sometimes have a bogus daily high temperature or wind speed number after starting WD and having it read in the stored data from the logger for the last 8 hours or so overnight. (This only came to light recently because normally I leave the computer on 24 hours a day but due to remodeling here, I’ve recently had to turn it off at night. When left constantly on, I never see this bogus data. (Could it be a bug in Davis’s data logger?)
Tom
P.S. There is no scale on the E.T. plot on the solar/UV graph which makes figuring out the actual measurement difficult. We should also add numbers along the vertical axis of the graph for the E.T. readings at some point…
humm, we need to deterine what units the ET is in (inches>?) can you compare with data on the console or what weather link says? thanks
i have added the numbers, and have converted the raw data to metric
updload a new verison now
try a new 9.85e now,
i have to run…
The E.T. problem appears to be ok now, at least based on the results today - it’ll take a few days to be sure, but the other two problems remain:
Once again, at 00:01am it shows a Maximum Temperature for the day of 88.3 degrees (F) when it was actually about 65. Could this be a bug in the midnight rollover? I’ll have to use the reset function to clear it.
I am still seeing spikes of 1.0UV on the Solar/UV graph on a regular basis through the night when WD pulls in the archived data from the logger. If you look at the Solar/UV grpah on my web page, you’ll see what I mean.
Cheers,
Tom
try a new 9.85e now,,, i have to run...
