Graph indoor temp?
You know, this is probably covered in the Help someplace, but I have not yet found it.
Is it possible to have a graph of the indoor temp somehow? Maybe add it to one of the other graphs? Not really asking for a new feature, just asking if the capability already exist and I am just missing it.
T!
see under setup, graph setup, extra options, and tick, plot indoor temperature
you can even set to plot extra temperature on the main screen graph instead too
Outstanding, thank you. I knew it had to be around in those menus someplace.
T!
Next question about the same topic, is it possible to turn off the indoor humidity on the same graph, but keep the indoor temp?
T!
i would set the indoor hum colour to match the background graph colour so you cant see it
try that
Thanks, I tried that, and it worked OK except that it displaced the Humidity label. I also assigned the Indoor Humidity to an unused sensor on the graph only, and that zeroed all the data for the Indoor Hum graph line. Both approaches seem to work, was just wondering if there was an actual selection to achieve this that I had missed.
T!
