In the graph on the mainscreen it is not possible to set the max. range higher then 60. The field will allow but the max value is 60. Is it possible to make it go higher? As you can see I have a baro scale between 974 and 1034 hPa. I’d like to have a scale between 974 and 1044 (value of 70)
Thanks a lot!
WD v10.10v - Have you tried Setup, Graph setup, Max Range, Maximum barometer range (hPa)?
Yes, that’s what I’m talking about, you can’t go higher than 60.
Yes, that's what I'm talking about, you can't go higher than 60.
Must be the La Crosse WS-2305.
I use the OS WMR-968 and I stopped trying after a setting of 260.
yeah, there is no limit
you are a little confused
i guess its not very clear
what the setting does is limit the maximum range, with the maximum value being set auto…i.e if the reading goes over 1034, then the graph will auto scale up to always plot the barometer…
if you have the range too high, then you loose resolution
so the summary is, dont worry, wd will auto scale above 1034 if your barometer goes over that
