Good tip with problem with small size with Fire Fox browser
Do you have your taxes done or are you looking for reasons to put that off? :smiley:
  • Jim
Sure Mike, that would be great. It can be cloned for the MML page too :slight_smile:
Send it along and I’ll add it to the distributions.
Thanks!
Ken
Ken don’t publish it yet, I am working on a MML template page and I see an ajustment to the javascipt I might make. I will reply when it is ready.
Jim, I started work on my taxes today LOL
Ken, I emailed you the wdl-mml-pages see readme.txt inside, look here for live examples
http://www.carmosaic.com/weather/mesomap.php
http://www.carmosaic.com/weather/live.php
This version is compatible with valid doc type xhtml while allowing dynamic resize
the SWF while resizing the window in Firefox or IE
The alternative to this method is to set the swf width and height to static settings.
Swf width and height can be set to 100% but then it will not work correctly in
Firefox when a xhtml doc type is used
Tested in IE6 and Firefox 2.0.0.12
Thanks Mike! I’m adding them to the distributions.
Ken
It works fine,but when i switch back to my view in IE (ie-tab,you know) my hole css-template is changed,and looks horrible,it goes even out of screen…Help on that anyone ? Is there a way to hide this from IE ,so that the thing works both on IE and FF ?
Whenever I need to troubleshoot a HTML problem I always start with the W3C Markup Validator
Hope that helps
good tip,kinda dumb of me…Found 39 errors so far…
THX
down to two faults now,but still the same(dwarf WDL),but maybe i am in the wrong post,i tried the carterlake templates,but i can’t get them to work,just getting letters or nothing at all ! :oops:
WDL on this page?
You can set width and height in pixels instead of percent
var widthOfWdl = “800”;
var heightOfWdl = “600”;
yes,that’s the page,it works when i pad out the two lines suggested here,but as i said ,the style sheet is messed up and it does not work anymore in IE,or is that not so with you guys ? i am gonna change my http://www.akker.be/dark_orange_bold.html template in thes settings…See what it looks like…
OK,this works for firefox,but now IE get’s crazy on me…After some thinking (and reading… :oops:) it seems to work for both party’s now,would you to give me a hoot if it looks the same at yours…? THX
Thanks for the script wdl-mml-forcesize.js now it works perfect. It took a while before I found the option “so.addParam(“wmode”, “transparent”);” so the fly-out-menu didn’t got hidden by the flash. :slight_smile:
try this as your header html 5
page looks fine to me in the latest version of firefox
this thread is 9 years old though that you have grave dug 8O
