German text after updating to 9.85e
Brian,
I just updated from WD 9.83c to 9.85e and I noticed that I am getting German text on the webpage above the screenshot image.
"Diese Seite wurde mit aktuellen Daten einer DAVIS VP Wetterstation erstellt. Dr
If you search on “german” you will see another recent thread on this subject, seems to be something that comes and goes. Brian’s response last time was;
quote
oh, a few others have reported that, but i have never been able to duplicate
try deleting the datahtm2.txt file and restart wd
Cheers
Brian
unquote
The problem never came back for me.
Brian,
Deleting the datahtm2.txt file and restarting WD corrects the problem.
But I found a way to duplicate the problem.
Setup → Setup web files/web page → View a web page.
The datahtm2.txt file will now have German text at the top.
humm, i still cant duplicate with that method
do you have ticked, let me manage the datahtm2. txt file?
The let me manage the datahtm2.txt file is not checked.
I exit WD.
I then delete the datahtm2.txt file.
I then restart WD.
I check the datahtm2.txt file and it is correct.
I then select Setup → Setup web files/web page.
From there if I just click OK without making any changes on that page, the datahtm2.txt file will now have been updated with German text.
I am able to duplicate this every time.
[/quote]
odd
i still cant duplicate…but i have done some small changes to the code for the next version that might help
Murry, what OS do you have?
can anyone else duplicate following murrays steps?
i even put in a specail warning message.////
can you post here the datahtm2.txt file murray after it changes to german?
Hi Brian, The let me manage the datahtm2.txt file is not checked.
I exit WD.
I then restart WD.
[/quote]
can anyone else duplicate following murrays steps? i even put in a specail warning message.//// can you post here the datahtm2.txt file murray after it changes to german?
I can duplicate the German text in the
ah ha
i can do it if i set the station type as a vp
well, blow me down
looking now
found the bug!
it was a end, else in the wrong place, and only affected VP users
no wonder i could never duplicate it!
uploading a fix now
a new 9.85e fixes it
so its OK now?
if so, thats one obscure bug squashed that has been there for along time!
thanks for finding it and how to duplicate it guys
Brian,
Yes, it is working correctly now.
Thanks for all your efforts in fixing this.
