As german translation I did long ago (2007) and a lot of extensions in WD were added, a workaround is highly recommended.
Actually there could be seen a mixture of german / english labels / words and also typos in. :?
I could have a look into and do a workaround in order to actualise german language.
@Brian: dont know, whether you received my email or not concerning translation.
Could you please email me that relevant .ini files?
could I use that translations I did in the past when we worked on the translation project 2007 within the language.ini file as shown in the translated file? - So I would copy the lines into my language.ini file - if that works?
Hi Brian, may I ask, when will that be? . More than 260 views on this thread may indicate there are a lot of german speeking users interested in a revised version .
Please let have a clear information how we will go on. Knowing about your rare available time - thank you for your support !
“You get WD to create the “language.ini” file, via the language setup menu and sub menus under “Setup”.
You add in your language after each = for each line.
Then you get WD to reload that back in via the langauge menu items and set to use that.”
