Please can you tell me - how do you (or anybody else) do the translation in german? Is there maybe a “ini”-file where the german words are written in - or something else?
If so and when possible - please tell me - I would love to correct some things which are wrong translated - and causes some problems - especially for some very very new users like me which are using Weather-Display just some days/weeks.
try:
setup, language setup, use language.ini file
then create for first time
then find the language.ini file, where wd is installed, and set new words to use after the = for the ones/things to change
and then set to load the language.ini file in the language setup sub menu, and then also set to auto load at start up
should do the trick
there are some web images that I still need to be able to be updated via this method
let me know the next most important one maybe
Hello Stephan, maybe you can ask fellow German WD-users for their language.ini? Why inventing the wheel twice
To Brian:
You asked for something important to translate (via language.ini)?
What about the direction names: n, s, e, w, nnw, sse, etc.
I’m sure that would be appreciated by others as well !?
i did do some conversion …the main screen direction names should be converted OK if you set to use german language in the language setup…yes?
but yeah there are others
