FYI: WS2310, 12z and Errorlog
Checked programerrorlog.txt this afternoon and found the following. Passing along for your information:
Resetting rain daily value , day: 16
Resetting wind/temperature daily value , day: 16
ERROR: Invalid floating point operation at time/date 12:02:32 AM 6/16/04
Resetting rain daily value , day: 17
Resetting wind/temperature daily value , day: 17
Program continues to run.
the daily reset of wind/temperature/rain entries are actually not errors but indications that the program is running normally.
ERROR: Invalid floating point operation at time/date 12:02:32 AM 6/16/04 is an error from the program and it looks like it had an issue on the midnight extremes and averages update perhaps? If your program is running ok and all extremes/averages data and images have uploaded ok then that may have been a glitch as you do not have a repeat for day 17.
Cheers
Well, there are days when I am not sure about the machine WD is running on. Day 18 cleared the values and had NO data overflow error. It could be also that I had transitioned from 10.6? to 12z, so something might have changed between the releases, ya think?
Program has been chugging since 11:00:53 PM 6/17/04 PDT with no problems, and I haven’t pushed any buttons, so all is well.
So cancel yellow alert on that one, if you would.
Thanks for your time and patience.
