Fwi
Brain,
I can’t find where WD sets the name of the FWI. The top of the report does not agree with the bottom half of the report.
http://weather.dcrooks.net/FWI.htm
Dan
http://weather.dcrooks.net/fwi.htm
is what you need to be uising/viewing
Sounds good…I don’t know where I came up with the FWI.htm filename for the link… :oops:
Dan
Mine is named “index”. See below:
Mine is KAZMESA12 which is the id I got from Weather Underground. So the index file is KAZMESA12.html.
I’m working on a method that will change that automatically to KAZMESA12.php instead of html so I can have some php code in it.
the fire weather info page was named FWI.htm but I changed it a long time ago to fw.htm
now, some web servers are case sensitive (unix based) and some dont care 8)
