I am not sure what you mean, Using Yahoo (aanaco) FTP I send everything to my root for WD rather then a folder some my home path is root or “/”
I would think home directory is root
Not sure what you mean
/home/xxxxxx/public_html/yoursite
I would use root so my full path should ne /home/www.mysite.com
Am I correct, I attached a filezilla login path which is not helpful
Here is what filezilla tells me
Status: Resolving address of ftp.mysite.com
Status: Connecting to xx.xx.xx.xx:21…
Status: Connection established, waiting for welcome message…
Response: 220-Welcome to the Yahoo! Web Hosting FTP server
Response: 220-Need help? Get all details at:
Response: 220-http://help.luminate.com/help/us/webhosting/gftp/
Response: 220-
Response: 220-No anonymous logins accepted.
Response: 220-Yahoo!
Response: 220-Local time is now 10:18. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 5 minutes of inactivity.
Command: AUTH TLS
Response: 234 AUTH TLS OK.
Status: Initializing TLS…
Status: Verifying certificate…
Command: USER [email protected]
Status: TLS/SSL connection established.
Response: 331 User [email protected] OK. Password required
Command: PASS ****************
Response: 230 OK. Current directory is /
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Extensions supported:
Response: EPRT
Response: IDLE
Response: MDTM
Response: SIZE
Response: MFMT
Response: REST STREAM
Response: MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
Response: MLSD
Response: XDBG
Response: AUTH TLS
Response: PBSZ
Response: PROT
Response: TVFS
Response: ESTA
Response: PASV
Response: EPSV
Response: SPSV
Response: ESTP
Response: 211 End.
Status: Server does not support non-ASCII characters.
Command: PBSZ 0
Response: 200 PBSZ=0
Command: PROT P
Response: 200 Data protection level set to “private”
Status: Connected
Status: Retrieving directory listing…
Command: PWD
Response: 257 “/” is your current location
Command: TYPE I
Response: 200 TYPE is now 8-bit binary
Command: PASV
Response: 227 Entering Passive Mode (9xx,1xx,xx5,xx,xx,xx)
Command: MLSD
Response: 150 Accepted data connection
Response: 226-Options: -a -l
Response: 226 594 matches total
Status: Directory listing successful
