Ftp
for some reason the ftp program is not in sync with local file names vs. remote file name. this happens when auto update is on however they are in sync went done mannually. Program version does not matter and have tried redownloads both shot and long. Stumped!!
Did you try disabling your firewall and testing to see if that is the problem?
ah,that will happen if a file cant be found
post here the contends of ftplogfull.txt file
, after it fails, so i can have a look see
have email log to you Brian. I have no firewall or anyother thing working.
FOUND IT… didnt do it, dont know how, but for some reason in the custom file creation in control panel screen the names of some file were label the same name. thanks Brian for that brain snap.
in the ftplogfull, it reported, cant find tideprediction.html
was that also one of the problems?
but, yes, if names are the same, then causes problems!
good you found it
