Hi Windy.
I am trying to make a web page for my weather display. I expected this to be easy. Heres what i done. Using WD ver 10.18q
Setup - Control panel - FTP/internetsetup - connections
I have permanent connection selected
i have input my ftp host - username and password
use WD own ftp selected
redials =2
Hit cancel and min con box selected
timeout=5mins
use passive mode selected (other stuff i’m ok with)
selected Main Internet Switch = ON
Nothing seems to be uploading to my web page. Only if i manually do this using (Flash FXP)
I have looked in General FTP Functions - all seems ok there uploading every 30 mins and selected ON (green switch)
On the Web Files Page Setup
filename i use is index
Web files location is c:\wdisplay\webfiles
Other stuff selected and then Update html file - View as web page and not found. But when i look in directory its there, manually select it and it runs.
Real Time clientraw Setup
Enable data uploading selected
uploading data every 5 mins using clientraw.txt
Other realtime settings:
Use FTP seetings selected
FTP server usernam and password all ok (i imported setting)
Sorry so long. But can’t understand why not working. Any ideas please?
Tony
