FTP METARs
Hi everyone,
Is it possible, and if yes, How do I upload all the METAR data that I download, to my webserver so I can display the information…
regards to all, but inparticular Brian and Julian :slight_smile:
2 ways spring to mind
if you are using custom tags, then you can use the %metar/report=%
and put the name of the metar file at the end, e.g NZAA.MET
or tick to inlude text file, on the metar/ftp download setup page, and the text from the metar will be included on your wd default web page
or in the custom web page setup, tick to use downloaded airport metars
and then there are custom tags for each parameter (eg temperature) from each downloaded metar
that way , using the custom screen, you could create your own mesomap showing the data you want from the metars you have downloaded…
Thanks. I will get to work on that sometime this week. The mesomap was something that I was looking to create… :happy7:
there already is a mesomap setup you can use…and you set a metar as a data source…i.e put in metar name, e.g NZAA.TXT
but you might like to create your own (using the custom tags)
you can even have live data on a custom screen, sourced from other peoples data…e.g as the clientraw.txt file !
